tonymanson
Message par tonymanson »
How to clean your kitchen right?
The kitchen seems to be a challenging place for all housewives out there because we all know that kitchen messes happen all the time. It would be your kids' bowls of cereal spill on the table and spread on the floor, or a dropped food bag lying on the kitchen shelves; even a broken plate is waiting for you whenever you go to your kitchen. These disasters are happening every single day in our lives, but you might think that dustpan and broom are the only way to sweep them away, in fact, the best vacuum cleaners in the world are something missing in your house right now. A best-rated vacuum can bring you an effective way to do the cleaning task, make it a lot faster and easier. More than that, a vacuum can reach those hard-to-see places where all the dust, dirt, and grime traps lurk behind your sparkling kitchen. Bring along your top-rated vacuum cleaners and check out these tips to make your kitchen clean inside out.
  • The refrigerator
Before you do anything with this electric device, make sure to shut off the waterline and unplug it. To unplug your refrigerator, some might need to move it far enough to touch the wire. It would be lucky if your huge refrigerator is on wheels, which helps a lot and makes it easier, or else please ask someone to help you move it and prevent leaving scratches on your hardwood floors. It is essential to clean the condenser coils in your refrigerator regularly to ensure your device works efficiently over time. To start off, you can use the brush to gently remove pet hair, dust, dirt from the condenser coil. Next, use your vacuum's brush attachment to remove the remaining debris. Lastly, make sure to put the suction power in mild option before starting to clean the sides of the refrigerator, as well as the walls behind and around it. And don't forget to floor under your refrigerator. Now you are all set, cleaned refrigerator, cleaned floor, cleaned wall. Plug the device back it and gently slide it back into place.
Check This Out: Best vacuum cleaners on the market
  • The dishwasher
This appliance also needs to be unplugged and rolled out of its place. Most dishwashers are installed securely into their positions, making a lot of debris stuck behind the machine's seal and gave us a hard time removing them. Because of this reason, you can use a canister vacuum with its crevice tool attachment or a handheld vacuum to suck up all the dirt, grime, crumbs that are hiding under the base of your dishwasher. Another part of this machine that also needs to clean is the space between your kitchen dishwasher and other appliances. You can use either a duster attachment or even an extender wand of your vacuum to reach those places clear out anything trapped there.
Selected For You:
TheKingLive
Review for Miele Complete C3 Powerline Vacuum Cleaner
A kitchen is where there are many hiding spots for the dirt and dust staying time after time. Moreover, your own kitchen appliances make it harder for you to bring yourself up and clean this part of your house. The tip is to choose yourself the Top Rated Vacuum Cleaner you would find or even robot vacuums to clear out all those hard-to-clean places on a regular basis. And in the end, the feeling of accomplishment and a sparkling kitchen is genuinely yours.
Modifié en dernier par tonymanson le jeudi 25 mai - 9:34, modifié 3 fois.
nomansland
Re: Bonjour
Message par nomansland »
Salut et bienvenu . ça va pas ètre facile avec un T3 dans Paris !!
a+Stef
Re: Bonjour
nomansland a écrit : ↑jeudi 27 oct. - 6:13 Salut et bienvenu . ça va pas ètre facile avec un T3 dans Paris !!
a+Stef
le gouvernement veut prendre son temps dans le dossier "Z.F.E", à voir,
x@v :motus:
Re: Bonjour
